  3. Error message # 24??
  • Subscribers 163
  • Views 14225
archive over 18 years ago
I am trying to load a netlist from a translated pcb from Orcad 9.1 to allegro 15.7. When loading the netlist I get this error message........ Does anyone know what this means?
------ Preparing to read pst files ------
#1   ERROR(24) File not found
     Packager files not found
Originally posted in cdnusers.org by unclerob
    Assuming that you're using Files->Import->Logic in Allegro you need to be sure the "Import Directory" is set the the directory that holds the file "pstxnet.dat"
    Originally posted in cdnusers.org by CDL
