  3. Error When Generating Drill Legend
  • Subscribers 161
  • Views 14147
archive over 19 years ago
We have recently upgraded to 15.7. Since the upgrade, when I try to generate the Drill Legend, I receive the error "E- *Error* renameFile: file exists". I have to delete the previously generated "nc_param.txt" file before I can continue. This was not the case before and I also have the same problem now when generating artwork. Is there a way to set this to overwrite previously generated param files? Thanks in advance for your help.... Liana
Originally posted in cdnusers.org by Lianakcc
    You may want to check permissions on the files and make sure you have read write access.
    Originally posted in cdnusers.org by CTMusetti
