  3. Generating RS274x artwork without G36/G37
  • Views 605
archive over 18 years ago
Hi there,
I get this response from a PCB manufacturer regarding my generated RS274x artwork:
"these gerbers are generated with composite layers and negative plots (G36/G37 commands)
on such gerbers we can't do DRC check nor to ensure correct phototools ploting
please try to re-generate with stroke fill your copper pour instead with composites"
Can anybody tell me how (if possible) to generate my artwork without using the G36/G37 commands (although it seems like these at part of the RS274x standard)? I am using PCB editor 15.7 s066.
Any help is appreciated,
M. Vinding.
Originally posted in cdnusers.org by vinding
    Your board house needs to merge the composites into a single layer. Some CAM software does this automaically.
    You can not change the RS274X output from PCB Editor to not use composites.
    You could output ODB++ or Gerber 600.
    Another option is to find another suppler.
    Regards
    BillZ
    Originally posted in cdnusers.org by BillZ_EMA
