  3. Error message 102
  • Subscribers 163
  • Views 14830
Error message 102
archive over 18 years ago
I am getting the following when trying to Import Logic.  Orcad 10.2 to Allegro 15.7.  Does anyone have a clue?
#1   ERROR(102) Run stopped because errors were detected
netrev run on Jul 11 11:33:39 2007
   DESIGN NAME : 'DESIGN1'
   PACKAGING ON May 20 2003 12:20:37
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
  1 errors detected
 No oversight detected
 No warning detected
Originally posted in cdnusers.org by rscotts
    There should be a .log file somewhere that tells you what the error is. Check the ALLEGRO folder, Orcad netlists are generally written to the Allegro folder. Could be any number of things. First thing I would check is MULTIPLE same ref des's and/or funky net names with illegal characters.
    Good day.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
    I think the .log file will also give you the same details as the one that you already have stated. If it is something to do with multiple same ref des, then my guess is that you shouldn't have the net list generated, as Orcad will never generate netlist with mulitple ref des.
    Now that you have the netlist and that you could not import into the Allegro, my thought is that it is do with the Allegro symbols. Check for Allegro symbols (especially connectors with mouting holes) and make sure it matches with your Orcad symbols, in your design.
    Best regards,
    Kishore
    Originally posted in cdnusers.org by kishore
    You may also need to check the number of characters of the Allegro package symbols, if your length is more than 28 characters ( not 100% sure about the numbers) you may need to set the variable allegro_long_package_name in your system variable(This will allow 255 character length).
    While checking Allegro symbols and Orcad symbols make sure you check the pin number also ( for ex transistor may be E,B,C naming in schematic but Allegro symbol may have 1,2,3 numbering) .
    Hope this helps,
    Nagaraj.
    Originally posted in cdnusers.org by rajpcb
    I would check your ISR level. Go to Help>About
    There was a PCR for a netrev 102 error and it was fixed in an ISR
    Download and inatall the latest ISR.
    Regards
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
