  3. "Adjacent Layer Parallelism "
  • Subscribers 163
  • Views 5778
archive over 18 years ago
Hi!,
Any body explain,how to set constraint ,"Adjacent Layer Parallelism " in allegro tool.
Thanks in advance,
Satya
Originally posted in cdnusers.org by satya1234
    I think there is not any particular constraints for the purpose but a way is that you can creat offset among grids of different layer and then you can ran paralel.exe utility in order to verify that how much you are sucessfull.
    However may be there are much better ideas than above one.
    Originally posted in cdnusers.org by imaqsood
    I think there is not any particular constraints for the purpose but a way is that you can creat offset among grids of different layer and then you can ran parallel.exe utility in order to verify that how much you are sucessfull.
