  3. Adding pins to a hierarchal block
  • Subscribers 161
  • Views 14218
archive over 19 years ago
After adding a hierarchal block successfully, the shape of the block changes with no problems but I cannot add any pins to the new diagonal lines of the block.
The error that it gives me says: Bad point for pin addition.
Aproaching it in another direction is that I add the pins before I change the shape of the block and when I go to rearrange the pins into the block body and save the work done I get get errors with the pin names and text and the error says that the pin does not exist anymore. See picture for ref
  Thanks Paul Keefe
 Concept HDL 15.70-s030
Originally posted in cdnusers.org by pkeefie
