  3. Pin Swapping
  • Replies 7
  • Subscribers 162
  • Views 23241
Pin Swapping
archive over 18 years ago
I tried to swap pins on a component and it keeps giving me this error: Pin is not swappable because the swap code is zero ... pick again. How do I fix this so that the pins can be swapped? It does it with all of the components on the pc.
Originally posted in cdnusers.org by TimProctor
  • budnoel
    budnoel over 15 years ago
    Hello – Anybody have any suggestions on this?  I haven’t heard from anyone.  Thank you.
  • redwire
    redwire over 15 years ago
     The same principle applies here -- just assign the swap code to the swappable pins.  If you were to build it as single pins then you would end up having to do a function swap to get the same effect.
    The examples above should be clear.
