  3. Dynamic shapes on negative planes
  • Views 12902
archive over 18 years ago
Hi all, I have several negative planes (splitted)where where I am not seeing autovoiding for thru holes and vias, I attach several pics of the problem. After doing a research in the forum it comes out that in order to see autovoiding on negative planes I must set the options "Filled pads" and "Thermal pads" in the Display tab of "Drawing optiions", but then what was happening in the first image before setting this options where one shape autovoids the thru hole and the other not? Both are dynamic shape (smooth), SPB version 15.7 Thank's in advance. Regards.
Originally posted in cdnusers.org by luissito
    it looks like you're using donuts not clearance pads. i think if you switched to clearance pads, (in the top pic) the shape will be voided.
    Originally posted in cdnusers.org by KenM
