  3. concept hdl project convertion to Orcad
  • Views 17708
archive over 18 years ago
can it be done?
thanks,
Uri.
Originally posted in cdnusers.org by ukatry
    Yes the Orcad Parts (.olb) can be converted to Concept HDL.
    Best regards,
    Kishore
    Originally posted in cdnusers.org by kishore
    How can we accomplist it?
    Originally posted in cdnusers.org by imaqsood
    1. Open the project file (.cpm) via the Allegro Project Manager. For conversion feature always use Allegro PCB Librarian Expert.
    2. Go to Tools->Library Tools->Import->Orcad Capture to Design Entry HDL.
    3. Locate an Orcad library File (.olb) in the Library text box by selecting it using the browse button.The Part drop-down box is populated with names of parts in the selected library.
    4. Click a part to select it. The Aliases display box is populated with all aliases of the selected part.
    5. In the Options group box, pick one of the three choices.
    6. In the Design EntryHDL group box, select a library from the Library drop-down box.
    7. Click OK. The Capture part you specified will be imported into the library you selected.
    Best regards,
    Kishore
    Elgris Technologies has Concept->OrCAD and OrCAD->Concept schematic translators.
    The whole schematic (including libraries/hierarchy/graphics, etc ) can be converted between Concept and OrCAD.
    Check www.elgris.com for more details.
    Originally posted in cdnusers.org by luvishis
