  3. Regarding Gloss operation
  • Views 14313
archive over 18 years ago
Can anyone explain me what is Gloss operation,how can it be useful in allegro?
Thank in advance....
Originally posted in cdnusers.org by kingshar
    It performs following actions:
    1. Clean up lines and vias
    2. Eliminate vias
    3. Smooth lines
    4. Center lines between pads
    5. Improve line entry into pads
    6. Widen connect lines
    7. Convert corners to arcs
    8. Generate dielectric patches
    9. Fillet pad and T connection
    You can attach either the NO_GLOSS property or the FIXED property to the nets so that gloss does not modify the routing of these nets.
    Best regards,
    Kishore
    Originally posted in cdnusers.org by kishore
    Thank you very much Kishore
