  3. Measures taken when signal crosses splits
  • Replies 8
  • Subscribers 161
  • Views 17436
archive over 19 years ago
Hi everyone,
I would be greatful if anyone answer my query.
If a situation occurs where I need to cross the splits what r the measures that needs to be taken and why ? Also If a signal is crossing two splits that of power and GND what are the measures that needs to be taken.
Thanks in advance.
Eswar
Originally posted in cdnusers.org by eswar
    The simple answer is don't cross the split in the plane. If this is not possible, reduce your current loop to the absolute minimum. It is difficult to give a solution without knowing a lot more about your design. A bypass capacitor between the two planes at the point where you are crossing the split will help. Guardbanding is another way to maintain a small current loop.
    hpattie@entrisphere.com
    Originally posted in cdnusers.org by Hpattie
    Thanks for you suggestion. But what will be the value of decap and why
    The problem with crossing a split plane is that the return current cannot cross the split so it takes some longer path which adds inductance to your signal (i.e. slows it down) and the convoluted return path usually results in excess emissions (EMI). The faster your edge rate, the more you need to worry. I2C is OK, 800MHz DDR2 is not. Crossing a split plane will probably kill your DDR2 signal, especially if both reference planes are split.
    Originally posted in cdnusers.org by Kalevi2
    There are quite a good number of articles written on this topic, that you can find on the net. One good source to start with is Eric Bogatin's site at:
    www.bogatinenterprises.com
    Best regards,
    Kishore
    Originally posted in cdnusers.org by kishore
    Thanks for the reply
