  3. company logo to symbol file
  • Subscribers 161
  • Views 17631
archive over 19 years ago
What's the simplest way to get a company logo into a symbol file?
Originally posted in cdnusers.org by padmaster
    Take a bitmap of your logo and convert using this utility.
    Raster (BMP) to Allegro (IPF) - http://sourcelink.cadence.com/docs/db/kdb/2005/Feb/11022718.html
    Read the resultant file into your empty symbol.
    If your logo is complex, it may be wise to retrace with shapes to minimise the data size.
    KP
    Originally posted in cdnusers.org by kp
    Find the procedure to import .BMP/JPEG/.JPE/.JFIF/.GIF/.TIF/.TIFF/.PNG/.DIB file to Allegro or PADS layout:
    Uses:
    1.When the customer provided the logo or drawing in bitmap(or Above any format) format.Without creating manually ,can be imported directly to the layout.
    2.When the customer not given logo and asked us to down load it from the web. Down load the logo and convert it into any above mentioned format and import the same into the layout.
    Procedure to import the .BMP/.JPEG//.JPE/.JFIF/.GIF/.TIF/.TIFF/.PNG/.DIB format file to PADS layout:
    1.Save the above file in monochrome .bmp format.
    2.Copy the script file BMP2ASC file in the same directory.
    3.Run the command BMP2ASC bitmap.bmp ascii.asc 2 26 0 0 at DOS command prompt.
    Where BMP2ASC is the script file name.
    bitmap.bmp is the bit map file name
    ascii.asc is the converted output in .asc format.
    This command will scan the data and convert it to horizontal lines 2 mils wide. These lines will be placed on layer 26 (silk-screen top), and the lower left-hand corner of the image will be at 0,0.(w.r.t.,PADS Layout).
    4. Open up a new PADs file, and import the ASC file. Be sure to set the color and the minimum display
    Procedure to import the .BMP/.JPEG//.JPE/.JFIF/.GIF/.TIF/.TIFF/.PNG/.DIB format file to ALLEGRO layout:
    2.Copy the script file BMP2ASC and .bmp file in the same directory.
    4.Import the .asc file to allegro board file. OR
    5.Import it to PADS layout.Export DXF of the same.
    6. Open up a Allegro file, and import the DXF file.
    script file BMP2ASC is available under web.
    I hope problem is solved.
    SATYA SHANKAR.G
    Originally posted in cdnusers.org by satya1234
    This issue has been answered many times on the forum already and you can
    simply search the forum for "logo" and you will find many posts.
    Here is one of the more recent posts on the subject:
     Subject "making a logo for placement on a pcb"
    http://www.cdnusers.org/Forums/tabid/52/view/topic/forumid/5/postid/4258/Default.aspx
     I personally load everything in the Adobe Illustrator, covert to DXF and
    import into Allegro.
    KP mentioned a very key point "If your logo is complex, it may be wise
    to retrace with shapes to minimise the data size."
    Sometimes these imported logos can grow very large with many small
    segments which will make it hard to manage in Allegro so I convert them
    over to shapes.
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Thanks to all for your help.
