  3. Error in HDL Direct: B is not a legal Concept Name
  • Views 13185
archive over 18 years ago
I got this message on Concept write, with an error on HDL output.
All our symbols are made in the same way. It works on 15.7 but since few days I got this error on all schematics.
Even if I create a new project, adding a single resistor and write, I got it.
I also have a strange behaviour with HDL output on the tools/options menu from Concept:
Both "options" button under Create Netlist return the same error message:
A required resource was unavailable.
Does anybody know where is the faulty setup for that?
Thanks in advance.
Originally posted in cdnusers.org by willbi
    I also just noticed this issue last week. I've filed a CCR# 490418. It has just been fixed internally and the SPB16.0 ISR containing this HotFix should be available either this Friday (10/5/07) or next Friday (10/12/07).
    Jerry G.
    Originally posted in cdnusers.org by geraldg
    hello and thanks for the fast reply
    I found solution # 11378492 on Sourcelink.
    They tell that the latest hotfix is available and fix this (SPB16.00.007).
    I try it right now...
    willbi
    The latest hotfix SPB16.00.007 fixes the problem.
    willbi
