  3. Termination resistors
  • Views 15017
archive over 18 years ago
Can anyone explain what is the need of termination resistors and also how they can be placed such that its need is met.
Thanks in advance
Originally posted in cdnusers.org by kingshar
    The most common termination resistor is a source termination. It is used to match the output impedance of a driver to the transmission line impedance to reduce overshoots and undershoots. It should be placed as close as possible to the driver. Practially speaking, a distance of 750 mils is usually acceptable unless you have a very fast driver such as a high frequency clock fan out buffer.
    Originally posted in cdnusers.org by Kalevi2
    Thank you very much ,Kai Keskinen
    Sarath Kumar
    PCB traces should be terminated when the trace length exceeds the following condition:
    Length > tr / (2 x t pd )
    Where tr = Signal rise time, t pd = Signal propagation delay.
    Most used termination types:
    Series [Source] Termination :
    should only be used with one load on the line, but only requires one resistor [R], placed near the source.
    Parallel Termination :
    Used with any number of loads.Requires one resistor,placed near the receiver.
    Thevenin Termination [or Split Termination]:Placed near the receiver.
    Satya Shankar.G
    at&s Ecad.
    Originally posted in cdnusers.org by satya1234
    archive over 17 years ago
    Thank you satya
    Hi satya,
    You discussed about series and parallel termination and that was really nice. can u make me clear about other terminations ex Differential , AC, Thevenin.
    And what are the conditions for each of them to be used?
    It would be so nice of you!!!
    Thanks and regards
    Niraj
    Originally posted in cdnusers.org by nforniraj
