  3. Allegro 15.7 bug?!?
  • Subscribers 163
  • Views 13489
Allegro 15.7 bug?!?
archive over 18 years ago
Hi all,
I'm using Allegro 15.7 and there is some stupid bug that ruined my work several times.
The problem: There is no snap. For example when I try to make connection from a pin allegro doesnt snap to this pin/wire/etc.  I dont know how to explain it better. I dont know what causes it either. After some time the damned snap doesnt work.
If anyone knows something about this pls help. I just cant save a new version of the file every 10 minutes
Originally posted in cdnusers.org by Iriot
    Ensure that you enabled the "Snap to connect point" check box when in route command.
    Best regards,
    Kishore
    Originally posted in cdnusers.org by kishore
    One of the guys here had this problem today. We never bottomed the precise cause but the fix was to exit allegro, restart and run DRC update.
    Hope this helps,
    Andy
    Originally posted in cdnusers.org by agulliver
    To trouble shoot this problem when you encounter this problem check your find filter to make sure
    it has pins selected. Also make sure as stated above you have snap to connect point.
    And as a good practice download the latest ISR from sourcelink.
    BillZ
    EMA Desgin Automation
    Originally posted in cdnusers.org by BillZ_EMA
