  3. How to display pin number in allegro 15.7?
  • Replies 7
  • Subscribers 163
  • Views 23293
archive over 18 years ago
thanks, how to setup so pin number can be displayed.
Originally posted in cdnusers.org by watchdog1976
    Go to color settings.
    Switch on  :
    Group=Geometry,Global visibility=Pin_Number.
    Enable Global visibility=Pin_Number.
    Satya
    Originally posted in cdnusers.org by satya1234
    go to Group=Geometry
    Under Package Geometry subclass
    Enable Pin_Number.
    Satya
    i have tried in this way that you said, but pin number still visible.
    untitled.zip
    i tried in the way that you said, but still be visible.
    attached file is the setting, plz check it. thanks really.
    untitled.zip
    The text size for the PINs might be very small. Switch of the pins in dispaly visibility and check as the text might be under pins.
    Originally posted in cdnusers.org by sriramssr
