  3. some questions about Allegro 15.7!!!
  • Views 13064
archive over 18 years ago
what is the function of these layers:
(1)"package keepin"  "route keepin" , how about the difference about them?
(2)assembly_top;
(3)board geometry;
(4)cut_masks
another question is the word of "slot", what is the meaning of "slot"?
thanks!
Originally posted in cdnusers.org by watchdog1976
    archive over 17 years ago
    (1) Package Keepin:Package keepin subclass can be used to define a constraint area within which the components are to be placed ( generally this command is used with autoplace command ) If the components are placed manually outside the keepin area , design rule check report generated shows the DRC error for voilation of constraint.
    (2) Route Keepin:Route keepin subclass can be used to define a constraint area within which the tracks are to be routed ( generally this command is used with autoroute command ) If the tracks are routed manually outside the keepin area , design rule check report generated shows the DRC error for voilation of constraint.
    (3) Assembly Top: This subclass is used to define component details for assembly , assembly instructions ( that are useful at the the time of board assembly ) etc...
    (4) Board Geometry:Generally used to define outline for board ( that defines actual size of the board ).
    (5) Cutmarks: can be used instead of bord outline ( for manufacturing convinience ).
    Prajakta
    Solar Biotronic Laboratories Pvt.Ltd.
    www.sblindia.com.
    Originally posted in cdnusers.org by psj
    Assembly-top (bottom): also used by tesprep process to know where component's body is located
    Should be as close as possible from reality for this reason (external dimensions)
    Hope this help,
    jean-charles
    Originally posted in cdnusers.org by jch teyssier
