  3. RS274X gerbers don't show copper
  • Replies 8
  • Subscribers 163
  • Views 4056
archive over 18 years ago
I have a recent design that exhibits very strange behavior.  I am generating artwork in RS274X format. When I view the the individual films inside Allegro, all layers look as they should. However, when I try to validate the artwork in a thrid party tool, the copper layers are empty/blank. The odb++ works just fine, all the copper is there. But in two different gerber tools, the copper layers don't show up when I try to view the gerbers. I imported a film_setup file that I just used on a production board with no issues what so ever, but the new file in question still exhibits this strange behavior. It seems it may be a seeting in the brd file database that is incorrectly set, but I cannot find anythign that looks out of place. Has anyone seen this before? Does anyone have any ideas/suggestions that may solve this issue?
Thanks in advance,
DC
Originally posted in cdnusers.org by dc32178759
    Is it just the certain copper layers or all of them?
    What about the silks / soldermask are they blank also?
    KP
    Originally posted in cdnusers.org by kp
    Hello KP,
    It's only the copper layers. All the other layers, silk, paste, mask and assembly all are fine. THey are jsut as you would expect them to be.
    Is they are positive planes or negative planes?If it is negative planes you will get reverse image( in gerber tool )of what actually you see in data base.Make it positive in gerber tool you will get actual image.
    I hope this solves your problem.
    Regards
    Satya .
    AT&S ECAD.
    Originally posted in cdnusers.org by satya1234
    Hello Satya,
       All the planes are positive in the database, and I generate all layers as positive.
    Thx,
    DC
    Can you post a screenshot of a sample film record and setting along with a cross-section
    KP
