  3. ABOUT ROOMS in Allegro pcb PERFORMANCE
  • Views 15693
archive over 17 years ago
can any one explain  need of Rooms and how to create and use them effectivley.
Thanks in advance
Originally posted in cdnusers.org by kingshar
    Hello Kingshar,
    This will be helpful for placement of components in a group For example: power components in a group etc.,
    STEPS TO BE TAKEN IN ORCAD :
    Select the group of components to be grouped and go to edit properties u will find there a column room
    Specify the name you want like 'pwr' for power group and generate the netlist in conventional method
    STEPS TO BE DONE IN ALLEGRO :
    Import the netlist
    Add rectangle in the board geometry-top room and add text to it naming the group 'pwr' after clicking on the group shape
    Edit properties of the shape and there will be a property room type where HARD has to be typed
    Then go to PLACE----AUTO PLACE---TOP GRIDS (specify the grids eg:50) followed by clicking on the group shape
    Followed by PLACE ---AUTO PLACE ---ROOM and specify the room name
    Check for further drc's .
    Satya
    at&s ECAD.
    Originally posted in cdnusers.org by satya1234
    Thank you Satya for the reply.
    If you don't mid Can you please explain me the whole process of Auto placement....
