  3. How to restore the settings ?
  • Subscribers 163
  • Views 14929
archive over 18 years ago
Hi Recently I have created new user account in win XP. With this new account all settings like strokes & appearance is same as by deafult settings. Please let me know how to restore all this as was in my previous account. Is there anything to do with env file ?
Originally posted in cdnusers.org by Rajiv
    All of your Allegro configuration settings are stored inside of the PCBENV Directory which is created when you execute Allegro for the first time. If you want to restore your previous configuration from the old account you will need to copy the entire contains of the PCBENV Directory from the old account to the new account PCBENV Directory. This PCBENV Directory is normally located in your HOME Directory and a quick way to find out where that is open up a DOS Prompt (Start > Run > cmd). The HOME Directory is different for each login and you may need to login to the old account to locate it, depending on your permissions.
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Thanx Dear..It worked. Regards Rajiv Vig
    Posted By Rajiv on 11/14/2007 7:53 PM
