  3. who can explain this?
  • Views 12966
archive over 17 years ago
"This must be adhered to for multi-up arrays to insure no trace breakage when de-paneling the array"
i can not understand the exact meaning of above sentence.
especially some key words:
(1)multi-up;
(2)array;
(3)breakage;
(4)de-paneling;
who can explain the meaning of these key words and above sentence?
the more deatiled, the better.
thanks in advance!
Originally posted in cdnusers.org by watchdog1976
    A panel is a pcb on some what 60 cm * 60 cm that contains 1 - N smaller boards who is the actually customer pcb.
    Not shure but no breakage when depaneling, could be the capability to avoid tracks breaking, when you remove a single board from the panel.
    Multi-ups and array. could be that the manufactor have a system that carries several panels. When depaneling pcb's from all panels at one task, demand very precise setup of the panels to avoid cutting into a pcb on one of the panels.
    But it would be much more easy to reply on, if the complete text was precent.
    Originally posted in cdnusers.org by Malmir
    Your explanation is very good and helpful for me. especailly the explanation of "panel" .
    another quesion is if track = trace? if it is the same meaning in diffenrent words.
    thanks.
    the complete text is:
    Traces should not be placed closer than 0.30 inch to the edge of the panel(edge of trace to edge of panel).
    1)This must be adhere...................................
