  3. Allegro to PADS conversion
  • Views 16334
archive over 17 years ago
Hi Everybody,
I have one Allegro board file and client requirement is to convert it in to PADS POWER PCB.
Can anybody tell the procedure to convert it in to PADS?
I need to convert the board outline and components ATLEAST TEMPLATE.
Thanks in Advance.
Sriram
Originally posted in cdnusers.org by sriramssr
    Hello Sriram,
    I hope there is no option to convert allegro to pads in one shot. But you can generated DXF and inport into pads.
    Satya
    Originally posted in cdnusers.org by satya1234
    Hello Sriram,
    I hope there is no option to convert allegro to pads in one shot. But you can generate DXF and import into pads.
    Satya
    Hi Sriram,
    This is obviously the wrong forum for this discussion. You might try the (tor)Mentor.com site, but I'll give you a little forewarning... IT NOT EASY. There is NO direct translation to PADS. From PADS, yes, but not to pads. You can buy the CAM350 option and import Allegro gerbers and the like into a PADS format compatible with PADS. Aside from that, yes, you could output DXF (in a PADS compatible PADS dxf format, like IntelliCAD), but that will only get you graphics. To convert a usable database, you're outta luck.
    Tell you customer to download the Allegro FreeView, and view your database. If they're only in need of fabrication data, that's all they need. If they need an intelligent database as an end product, they should have had you start in PADS.
    Good luck.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
