  3. how to unroute track?
  • Subscribers 161
  • Views 19301
archive over 18 years ago
almost 50% track has been routed aumatically, but the quality is not good.
now i want to unroute these tracks.
how should i do? please do not tell me to delelete it one bye one.
thanks
Originally posted in cdnusers.org by watchdog1976
    I think You may have to retain outer layer traces as it may be only fanout traces.
    Switch on All the inner signal layers, select the delete option (X), select CLINES in the right side window, keep the curser at one corner of the area and drag it to the other corner (You will select all the traces where you want to delete) the press DONE.
    This will work out.
    All the best...
    Originally posted in cdnusers.org by sriramssr
    thanks for your help,  i have tried it. it is good.
