  3. Problem with colors in Allegro
  • Subscribers 161
  • Views 16824
archive over 18 years ago
I'm using the standard color palette from Allegro 16.0. At the attached screen shot you can see my problem. The brown layer is bottom and the green is top (the brownish background is a ground plane). But why are there cyan traces (cyan on top and bottom). I can't find a difference between the wrong displayed traces and the ones with correct display. Can you give me some advice?
Best regards
  Guenther Jehle
Originally posted in cdnusers.org by guenther.jehle@entner-electronics.com
    Check to see if the green nets are highlighted.  When the green wires change layers thru a via they still appear green as if the whole net was highlighted in green.
    Randy
    Originally posted in cdnusers.org by rb
    Ok, this was the solution. Thank you!
