  3. Highlight Dummy_Nets
  • Views 13172
archive over 17 years ago
is it possible to highlight all pins with dummy_nets in a board layouted with Allegro 16.0 ??
Thanks in advance
Tom
Originally posted in cdnusers.org by Tom33
    Select Hilight command
    Select the colour you wish to use
    In the find filter "Find By Name section"
    Set the selection criteria to "Net" and "Name"
    Type DUMMY in the Fillin to the right of the ">" then hit the TAB key
    All DUMMY nets will be hilighted
    Script that will perform the required action
    setwindow pcb
    trapsize 105
    generaledit
    hilight
    setwindow form.find
    FORM find name_type Net
    FORM find find_name DUMMY
    setwindow pcb
    trapsize 110
    Originally posted in cdnusers.org by Trykon
    Oops,
    GENERALEDIT isn't recognized in v15.7 What's it do?
    Originally posted in cdnusers.org by cadpro2k
    Sorry, that script was created using 16.
    16 has several application modes which are used for pre-selection (Choose the element to be worked on and then the command) which provide an environment in which commands used frequently in a particular task domain, such as etch editing, are readily accessible from right mouse button pop-up menus, based on a selection set of design elements you have chosen.
    General-edit application mode lets you perform editing tasks, including place and route, as well as moving, copying, or mirroring, for example.
    Etch-edit application mode customizes your environment to perform etch-editing tasks such as adding and sliding connections, delay tuning, and smoothing cline or cline segment angles, for example.
    Comment out, using a "#" sign in the begining of the line or delete the general edit line
    Again, sorry if that confused you.
    OK, thanks to all of you !
