  3. Error Generating Netlist ( Allegro Version 15.2 )
  • Subscribers 163
  • Views 15319
archive over 18 years ago
I am getting a error while generating netlist.Can anyone tell me what this error message means ?
Please note that, at first I was using a part in Capture Library which I modified and then I used it in the design. At that time , I was getting the below mentioned error while generating netlist. But when I generated a totally new part in capture  library and used it in my design ,  I was able to generate netlist without any error.
Can anyone help in this matter ...
Design Name:
e:\orcad\allegro
\design-ge.dsn
Netlist Directory:
e:\orcad\allegro\allegro
Configuration File:
e:\orcad\allegro\signoise.runcases.cfg,1
Spawning... "C:\Cadence\SPB_15.2\tools\capture\pstswp.exe" -pst -d "e:\orcad\allegro\design-ge.dsn" -n "e:\orcad\allegro\allegro" -c "e:\orcad\allegro\signoise.runcases.cfg,1" -v 3 -j "PCB Footprint"
Scanning netlist files ...
Loading... e:\orcad\allegro\allegro/pstchip.dat
Loading... e:\orcad\allegro\allegro/pstxprt.dat
#38 DDB_ERROR: Terminating character ':' not found on line 38.
              DDB_INFO: File e:\orcad\allegro\allegro/pstxprt.dat not loaded.
Error: Line 38 in file e:\orcad\allegro\allegro/pstxprt.dat:
   Error loading the parts list file
 Detected in function: ddbLoadPstXFiles
#1 Error   [ALG0036] Unable to read logical netlist data.
Prajakta.
Originally posted in cdnusers.org by psj
    Load thepstxprt.dat file into an Excel spread sheet and look in or near line 38. This will point you to what the problem is.
    Harold
    Originally posted in cdnusers.org by Hpattie
    I am attaching some part of the pstprt.dat file as can be seen below . I am not able to point what exactly the problem is......
    SECTION_NUMBER 1
    '@DESIGN-GE.SCHEMATIC1(SCH_1):INS54@CONNECTOR.CON16A.NORMAL(CHIPS)':
    C_PATH='@\design-ge\.schematic1(sch_1):ins54@connector.\con16a.normal\(chips)',
    PRIM_FILE='.\pstchip.dat',
    SECTION='';
    PART_NAME
    ALARM CANCEL 'SW ROTARY 1P-5W_4_4LEGDOME':; --------------- Line 38
    SECTION_NUMBER 1
    '@DESIGN-GE.SCHEMATIC1(SCH_1):INS1395@DESIGN27.SW ROTARY 1P-5W_4.NORMAL(CHIPS)':
    C_PATH='@\design-ge\.schematic1(sch_1):ins1395@design27.\sw rotary 1p-5w_4.normal\(chips)',
    SECTION='';
    PART_NAME
    MARK/ 'SW ROTARY 1P-5W_4_4LEGDOME':;
    SECTION_NUMBER 1
    '@DESIGN-GE.SCHEMATIC1(SCH_1):INS821@DESIGN27.SW ROTARY 1P-5W_4.NORMAL(CHIPS)':
    C_PATH='@\design-ge\.schematic1(sch_1):ins821@design27.\sw rotary 1p-5w_4.normal\(chips)',
    SECTION=";
    Prajakta.
    Can you delete 'SW ROTARY 1P-5W_4_4LEGDOME' this part.And place it once again from the schematic library.
    It may get solved. If not recreate the part once againg and try it.
    Satya
    Originally posted in cdnusers.org by satya1234
    Yes , I did the same thing , recreated the part and the problem was solved.
    But I was just trying to get what role exactly the files
    E:\Orcad\allegro/pstchip.dat
    E:\Orcad\allegro/pstxprt.dat
    have to play while generating netlist ....and due to what consequences errors associated with these files may generate ...
    Prajakta.
    archive over 17 years ago
    Please see the explanation for possible reasons for ALG0036 error in the link below
    http://www.orcad.com/documents/community.faqs/capture/cap3ab.aspx
    Babu
    Originally posted in cdnusers.org by babubinkarim
