  3. Command ID mapping
  • Subscribers 163
  • Views 13958
Command ID mapping
archive over 18 years ago
Hi all,
         I am using cadence allegro 16.0(Pcb editor), and currently I am facing this problrm -->
"E- (SPMHGF-8): No command ID mapping files (allegro ) found in MENUPATH." as a result, menu bar is actually dehighlighted, and I get these sort of errors , if I click on file, open, etc.. _.
No command was found for ID 45770.
No command was found for ID 45774.
could any one suggest me , what should I do?
Thanks and regards
Niraj
Originally posted in cdnusers.org by nforniraj
    archive over 17 years ago
    Niraj,
    I don't see a reply to your post but I assume you have resolved the issue.  I am currently experiencing the same problem.  How did you resolve it?
    Thank you,
    Ryan
    Originally posted in cdnusers.org by rousseau
    The first thing I would look at is your menupath statement that Allegro is reading. The menupath should point to your install directory and any allegro site or cds sites that you have. Example:
    set menupath = . D:\Allegro_Site/pcb/menus D:/1601/share/pcb/text/cuimenus
    Please open Allegro and type
    set
    at the command line and copy your menupath statement to a post here. We can then help you determine where Allegro is looking. Also post your installation directory.
    Originally posted in cdnusers.org by Trykon
