  3. Setting up groups
  • Subscribers 163
  • Views 14863
Setting up groups
archive over 18 years ago
Can someone tell me briefly the steps I need to follow for checking lengths of traces for a group of signals. Every time I think I have it, I don't. Thanks
Originally posted in cdnusers.org by MURPHYS
    I guess we can only measure the length of a single trace segment at a time by selecting the option Display --- Measure and then selecting the two end points of the particular trace...
    Prajakta.
    Originally posted in cdnusers.org by psj
    Why don't you go for propagation delay\Relative propagation delay CM settings. Here you can create groups or classes as you requested.
    Satya
    Originally posted in cdnusers.org by satya1234
    Maybe I wasn't clear. Here is what I am trying to do. I have several groups of about 20-30 nets each that need to be within 5mm and 25 mm of each other with specific trace width and space. I am pretty sure they are all correct since they were done the hard way in Orcad before I translated the board. However, since there were a few hiccups in the translation and I had to redo some connections I would like to double check all of these signals to make sure. I would like to do this via the program and not by querying lengths or a report. Thanks
    Sandy
    Let me clarify. I meant that they need to be within the 5mm or 25mm of each other in length.
    Sandy
    Use the constraint manager to create a match group for each group of nets. then assign the relative propagation delay property with the values you need. Be aware that the tolerance field is + or - from the target. Once this property is set, Allegro will generate a DRC error for any nets that are out of tolerance.
    Originally posted in cdnusers.org by Hpattie
