  3. Changing extents
  • Views 17922
Changing extents
archive over 17 years ago
I get this message when I try to dimension my PCB.
E- (SPMHA1-73): Text line is outside of the extents.
How do I go about redefining my extents? Thanks
Originally posted in cdnusers.org by MURPHYS
    Did you try changing the drawing extents in Drawing Parameters under the Setup/Drawing Size menu? You could also try a skill program that I use called autosize. It can be found on sourcelink in the list of submitted skill programs. Hope that helps!
    Originally posted in cdnusers.org by mwright
    I will give these a try. Thanks for the help.
    There's a skill routine available that's very handy for this - "autosize.il".
    Originally posted in cdnusers.org by dschaefer
    Hi
    Please check the text block size that you are using for the dimensions. The default is a size 9. On very small designs
    it may not beable to place the dimension text within the extent of the design.
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
