  3. Illegal characters
  • Subscribers 161
  • Views 18209
Illegal characters
archive over 18 years ago
Are there any characters that can't be used in CIS as there are in Allegro? I would like to verify this before getting too far down the road with libraries and schematic. Thanks
Originally posted in cdnusers.org by MURPHYS
    Hi
    If you stick with the standard asci characters you should be ok. There are other factors to consider that may affect your
    CIS database. SQL may have characters it does not support. Also the main concern is making sure your values conform
    to the needed out put. Allegro package names a-z 0-9 - (dash) _(underscore) In Allegro you can search on acceptable characters either in the help or sourcelink.
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
    Does this apply to pin names and signal names on the schematic as well as symbol names and footprint names?
    The most comprehesive list of legal charaters can be found by opening the help Documentation in Allegro
    and searching on acceptable characters.
    The first hit I get is Allegro PCB Editor Limits.
    All of the various limits are listed.
    Regards
    BillZ EMA Design Automation
