  3. Orcad PCB editor 16.0... big problem !
  • Views 13104
archive over 17 years ago
After several hours of work on my **.brd file I can't save it, I can open it but can not save any new change I get the following error: Program has encountered a problem ans must exit. The database will be saved (if applicable). Obtain the latest sofware update from Cadence and if problem persist contact Cadence Customoer Support Someone know what to do with it ?
Originally posted in cdnusers.org by Alex2
    You might try:
    Open Allegro in the folder your file is at. You don't have to open the .brd file.
    Type shell (carriage return)
    type dbdoctor
    See if Allegro can fix the file. It should give you some message.
    Almost forgot, type exit
    Good luck.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
    Tank you very much !
    That fix my problem !
    Alex
