  3. ALLEGRO PCB Stackup
  • Subscribers 163
  • Views 15909
ALLEGRO PCB Stackup
archive over 17 years ago
Hi All,
Is there any method to copy the "stackup" from one brd design to another brd design without changing anything?
Thank you.
Originally posted in cdnusers.org by AhmetOzsoy
    You can use technology files to export and import the drawing extents, accuracy, layer stackup and physical/spacing design rules.Use File >Export> Techfile... to export and File >Import >Techfile... to import.
    Originally posted in cdnusers.org by Trykon
    Or just use the existing board as a starting point and delete all etch from it. I find this faster than tech-import since I keep all my fab and assy drawing templates and film views as well where tech import does not.
    Originally posted in cdnusers.org by redwire
    With respect to the post from Trykon on technology files, you may want to consider using Constraint Manager for the export operation if using SPB16.0 as CM provides the ability to filter the export by stackup, physical&spacing constraints, electrical constraints or user property definitions. In CM, go to File > Export > Technology File.
    Originally posted in cdnusers.org by EdH
