  3. Conversion from Pantheon Layout to Cadence
  • Subscribers 162
  • Views 16138
archive over 18 years ago
Does anybody know if it is possible to convert from Intercept Technologies Pantheon Layout system into the Cadence Allegro PCB layout environment  ?
It is possible for me to get a Speccrtra .DSN file, from Pantheon, but I'm not sure this contains all of the information I need.
Regards
John
Originally posted in cdnusers.org by johndp
    Correct me if i'm wrong, Pantheon is a Mentor derivative. If it is the case that the files are the same as Mentor then SpecctraQuest can read it through the Mentor import interface. This in turn will create a .brd file, tracks and all. Have not done such a conversion for some time but I think that it worked okay barring the aesthetics.
    KP
    Originally posted in cdnusers.org by kp
    Hi Kp,
    Yes and no, it can read Mentor databases, but then saves in its own slightly diffferent format you need a converter to translate back to Mentor format.
    Regards
    John
    I do not believe that there is any way to rebuild from a .dsn and I am not aware of any other method, other than a complete rebuild. Once all the parts and netlist etc is into Allegro you could create a specctra database from both ends and read the routes back.
    KP
    KP, thanks for the info
    John
  • AcAe
    AcAe over 17 years ago
     A Pantheon job can be taken into Boardstation then converted to Allgro, contact AcAe (www.acae.com) for details of the DART migrtion tool.
     AcAe
