  3. Bond Finger
  • Subscribers 162
  • Views 20404
Bond Finger
archive over 18 years ago
I want more information about Bond Finger. It is a topic at Constraint manager in PCB Editor. If anyone known this, let me know in details. Thanks.
Originally posted in cdnusers.org by shiva
    Bond fingers are pad stacks that are used in Package Designs (Allegro Package Designer). These 'fingers', which are single layer pads, allow you to add a wire from a die to a finger. From the bond finger to other pins in the package, such as a BGA, you would use traces/clines just as you do in Allegro Editor to connect pins of packages.
    Originally posted in cdnusers.org by Trykon
    Thanks for your information.
