  3. command window is not working correctly
  • Subscribers 161
  • Views 14982
archive over 18 years ago
Using: Allegro PCB Design (Version 16.0)
I posted this issue some time ago, but didn't get the right solution. I'm an old style keyboard worker, so the problems are really nasty. Let's start typing to the command window:
add line
x 45.75 100.25
Now I want to reuse the last line ("x 0 0"). So I press cursor up... And nothing happens. First question: How could I use the command history? Ok, lets copy it by hand (via clipboard):
x 45.75 100.25
Now I want to change the value 45.75 to 50. To do this, I press the cursor left. And I can't believe it, I really get:
x 45.75 100.25Left
Ok. Remove the string "Left" and set the cursor with the mouse behind 45.75 to remove it:
x 45.75 100.25
 Now I press the delete button and I get:
x 45.75 100.2
OMG! Some other things are really nasty in the command window, but I think you get the idea of my problem. Is this behavior standard? I tested it on two other installations and it works the same wrong way. So please tell me, that I missconfigured something ;-)
Regards
  Guenther
Originally posted in cdnusers.org by jehle
    Hi, These are correct behavior.
    I think that there is no getting around it.
    Better get used to it.
    Tomo
    Originally posted in cdnusers.org by tashirot
    This is the answer I was afraid to get...
