  3. Title Blocks
  • Subscribers 163
  • Views 14353
Title Blocks
archive over 17 years ago
Hi Folks,
I'm trying to create a custom boarder with my custom title block in capture.  I can delete the default title block but I can't seem to delete the default boarder that appears.  Even if I go into schematic page properties and uncheck boarder visible under grid reference. Is there some other way to delete or hide this standard boarder?
GoNukes
Originally posted in cdnusers.org by gonuclear
    Yes,
    In "Options | Schematic Page Properties | Grid Reference" The only problem with making a custom outline is that it can be selected and moved unintentionally. Can be irritating.
    Ken
    Originally posted in cdnusers.org by canind
    Thanks Ken, But I tried that. I have the boarder visible display box unchecked. The boarder still shows up. Not sure if I need to set some other option.
    Hey,
    I found my problem. You were correct. I had to uncheck the Grid Reference visible tab.
