  3. Plot file (pdf) with embedded text
  • Subscribers 161
  • Views 14705
archive over 18 years ago
Hi all,
V15.7 -
Need to get a top/bottom assembly with searchable text in .pdf format
Can anyone explain the exact sequence I need to set this up? I've tried the Sourcelink solution, and it's still not giving me searchable/editable text. Anyone? What am I not doing right?
Spent 4 hours so far trying to set this up, changing settings and different printer setups.
Thanks in advance.
Mitch
Originally posted in cdnusers.org by cadpro2k
    Please goto File---- Plot_Setup----Tghen select Widows Tab and tick the Non-vectorized Text option and then generate pdf file.
    Irfan
    Originally posted in cdnusers.org by imaqsood
    That's exactly it! :) THANK YOU/THANK YOU/THANK YOU
    Mitch
