  3. to add gerber layer ORCAD-10.5
  • Subscribers 162
  • Views 14783
archive over 18 years ago
Hi all,
      I am using orcad-10.5 layout-plus.In my job by mistake layer stackup get modified & gerber data layer sequence & there respective conents get misalligned. Does anybody knows to add/modifiy geber layer content  in orcad?
        Also tell the difference between layout-plus & pcb editor?
Thanks in advance to all.
Originally posted in cdnusers.org by akcpcb
    You may have some offsets set in the post processing settings of Layout. That is the only way I can think of that gerbers would be misaligned on output.
    Layout is the old OrCAD product.
    PCB Editor is Cadence Allegro with all the fancy options stripped out.
    Originally posted in cdnusers.org by canind
