  3. Drill chart hole sizes
  • Subscribers 163
  • Views 13498
archive over 17 years ago
Is there a way of consolidating hole sizes? For some reason when I generate the drill chart I have two seperate listings that are both plated and .38 in diameter. Thanks
Originally posted in cdnusers.org by MURPHYS
    Edit the padstacks so that the drill figure, symbol and tolerances are the same for the drills and re-run nclegend
    OR
    Using the Drill Customization chart (Manufacture >NC > Drill Customization) you can edit the drill characteristics and then merge the drills to get a single entry.
    Originally posted in cdnusers.org by Trykon
    What size do you normally make the Drill/slot symbol in the padstack designer?
