  3. Extracting the Constraint settings...
  • Subscribers 163
  • Views 13170
archive over 17 years ago
Hi, We have started converting all Pcb Design Files existing in Pads to Allegro,in the process we had problem in the padstack( editing flash) while compiling the schematics,now the problem is fixed and could able to compile the schematic to Allegro database. Now,will i able to extract the constraints from the Pads converted to Allegro Design?Because my idea is to lay the same board as we did in Pads with all the constraints present... Hope someone could help me on this issue.. Thanks & Best Regards, Ramesh
Originally posted in cdnusers.org by rame
    Hi Rame,
    I doubt it very much, I guess you are importing an older formate of ASCII PADS databse, and using the Allegro translator option, I have played with this myself, and it does a decent job but, I think as for the rules etc, you would need to add these in again to the Allegro constraint manager.
    Stephen Grant-Davies (QuantumCad)
    www.quantumcad.co.uk
    Originally posted in cdnusers.org by stephen@quantumcad.co.uk
