  3. Adding Ground Loop around Board Area
  • Subscribers 163
  • Views 13081
archive over 17 years ago
Dear All In my current project I have to add ground loop around the 4 layer board. Further this loop will be shorted at connector with other grounds (Digital & Power)to make one point ground. What is the criteria for deciding upto how many layers we should make this ground loop area. What factors comes into play while deciding this? Thanks in Advance
Originally posted in cdnusers.org by Rajiv
    A loop such as this is usually intended to direct an esd event around the periphery of the board rather than through the more sensitive areas. Put the ground ring on each layer if possible and make sure it is on the outer layers.
    Originally posted in cdnusers.org by Kalevi2
