  3. Error with IPC netlist
  • Subscribers 161
  • Views 14274
archive over 18 years ago
Hello All,
I am usign Allegro for layout; I have completed the the design and generated Gerber files, IPC netlist, NC drill, ODB++ files.
Checked Open shorts with ODB++ file in valor and did not find any problem.
Tried to do DFM checks with Gerber files, imported gerber files, IPC netlist, NC drill in to the valor tool. But I am getting error that problem is with IPC netlist. I have generated the files in Allegro 15.2.
Can any body the solution?
Thanks in advance.
Sriram
Originally posted in cdnusers.org by sriramssr
