  3. NC Drill Legend setup
  • Replies 7
  • Subscribers 162
  • Views 20266
archive over 18 years ago
I have three questions regarding setup for NC legend. We are running SPB 16.01 on a Windows XP platform. 1. What is the best text editor to use to edit the default-in.dlt file? 2. Is there any way to control the line thickness of the legend chart other than editing after chart creation? If not, this would be a great enhancement; control of line (and rectangle) thickness for plotting purposes. 3. We have not specified drill symbols with our padstack creation. Is there a way to automatically generate symbols along with the legend table? I thought there was but I can't seem to find it now. Thanks
Originally posted in cdnusers.org by bulldog
    1. Personal preference. Just use one that doesn't add special characters. I use Textpad or Notepad.
    2. Not that I know of, but you can see if adjusting the Default Line Weight in Plot Setup helps. (FYI; if you are also doing a gerber, you can set the Undefined Line Width in the artwork control form)
    3. Select Manufacture->NC->Drill Customization then click on Auto Generate Symbols.
    Originally posted in cdnusers.org by Randy R.
    Thanks Randy.
    Does anyone know if there is an easy way to adjust the size of the drill chart ?
    Originally posted in cdnusers.org by LRCohen1961
    hi,
    you can control Drill Chart size by editing defaults-mils.txt file.
    it is located in installation directory>>cadence>>share>>pcb>>ncdrill etc.
    location path i dont know is correct but it is somewhat like this only.
    Poojan Garg
    Originally posted in cdnusers.org by poojangarg
    Thank you.
