  3. square box on trace
  • Replies 11
  • Subscribers 163
  • Views 20400
square box on trace
archive over 17 years ago
I'm just curious on why do some of my trace's have a square box around the corners?  It's not a DRC error.  and it's not on all the traces.
Originally posted in cdnusers.org by gonuclear
square_box.doc
    This occurs when that trace segment was placed by the autorouter. When you delete the cline attached to one side the remnant will stay there. It has to do with a fanout property on the cline.
    Originally posted in cdnusers.org by redwire
    The boxes can also be from a group property on the Cline that was cut or joined by routing from the other end of the net. Great for taking measurements along a net.
    Originally posted in cdnusers.org by JoeWi
    Do you have scheduled nets?
    That box is a T point.
    BillZ
    EMA Design automation
    Originally posted in cdnusers.org by BillZ_EMA
    Hmmm ....
    Also see this in our designs, but can't really nail it down to an individual cause - appears several possibilities from the responses.
    Is there anyone from Cadence on the forum who can elaborate? (What causes them, why they are shown, what can we use them for, how we get rid of them ..)
    Originally posted in cdnusers.org by dschaefer
    In the help under net schedule it explains what T points are and how to schedule them.
    Specctra also has virtual T's
    These T's are used in scheduled nets to control the length mostly. an example of this is a clock net.
    A single trace is route to a point (T-point) RefDes is T1.1 then it braches from the T to the module. The length from the T to the modules all have to be the same length.
    U1 to T1 length equals 1000 mils
    T1 to U2 length equals 500 mils
    T1 to U3 length equals 500 mils
    T1 to U4 length equals 500mils
    Usually these T's are their for a reason. You can use a via as a T-point.
    To verify this do a show element on the net and see if there is a T1.1 connections and if the net is scheduled.
    Hope this helps
    BillZ
    EMA Design Automation
