  3. Flood over single pad
  • Views 13628
archive over 17 years ago
Is it possible to "flood over" selected pads on a plane? If so, how? Thanks
Originally posted in cdnusers.org by bulldog
    Yes
    It is possible. You can use Edit>Properties filter on pins and use the DYN_THERMAL_CON_TYPE.
    From the pull down select full contact.
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
