  3. using the size property in Concept
  • Subscribers 163
  • Views 12583
archive over 17 years ago
Doing a design of experiment board with 2000 capacitors. Trying to get 1000 pairs tide in series on one end only. Trying to implement the size property on the components and net so that there will be 1000 pairs. Also trying to implement these pairs into a design reuse module which will be duplicated 3 times. Problem is the size property works ok for the components but the net gets tied to all 2000 components, how can I set this up for only two pins to be tied?
Originally posted in cdnusers.org by stump1019
