  3. Concept HDL Bus connection erorr
  • Subscribers 163
  • Views 13290
archive over 17 years ago
Hello Folks,
Please refer the attachment.
 I used  MERGE/TIE symbol for to split the signal PPC_D to PPC_D and PPC_D but I am getting error 188.Please explain how to split these bus into two .
NOTE: I am aware about The sum of the size of the signals connected to the input pins of a MERGE symbol must be equal to the size of the signal connected to the output pin of the MERGE symbol. But for above explained case how to do ?
Would any ideas appreciated.
Thanks & Regards,
Kuthalingam.M
Originally posted in cdnusers.org by lingam
bus_err.zip
    Hi there,
    I do not think you need the merge / tie symbol in this instance. It is legal to draw the following busses in concept.
    PPC_D<31..16>
    Then somewhere else:
    PPC_D<31..24>
    Where <31..24> is a subset of <31..16>. You do not have to "declare" these with a merge symbol. However, the subset <31..24> is only usefull when connecting to a vectored pin. And I know you wouldn't want to draw a vectored pin on a component, becasue it makes debugging so difficult. :)
    May I suggest :
    1/ Where you want to use a subset <31..24> of the bus <31..16>, show the bus in it's entireity, <31..16> then show taps for each required bits, <31>, <30> ... <24>. That way anyone reading the schematic knows the correct size of the bus, and can see which bits you are using.
    2/ Where the bus jumps through a vectored pin on a hierarchical block, again show the entire scope of the bus <31..16>. If you only need the subset in a different level of your hierarchicy, use the technique above. Bringing the entire bus through the hierarchy does not give dangling nets crossing the hierarchy when you move to layout.
    Does that help?
    If you were to rename the nets on your merge symbol as follows:
    Left hand net: ALL_BUS<63..0>
    Right hand top net: MSB_BUS<31..0>
    Right hand bottom net: LSB_BUS<31..0>
    It might better explain how the merge symbol should be used.
    Note that on the left hand branch you now have 64 nets. And on the right hand branches, you have two lots of 32 nets.
    In your example, you have 16 bits on the left hand branch, 8 nets on the top right and 16 on the bottom left.
    16 != 8+16
    Which is why you are getting an error.
    Originally posted in cdnusers.org by vealmic@uk.ibm.com
