  3. Length Matching rule
  • Subscribers 162
  • Views 16832
archive over 18 years ago
I've topology for databus like
Driver----------1.Res.2-----------Receiver
Min and Max Length From Dri to Res pin.1 is given.Similarly, for Res pin 2 to Receiver also, min-max length given.
So in EC, in Propagation delay tab,I fixed this min and max length for both the segments.
My doubt is  how to fix rules for length matching within a group(bus) and between groups.
In Relative propagation delay tab, I defined two rules.to fix the tolerance value for the above two segments.I think this will work only for signals within a bus.How to fix length tolerance to match signals between buses?
Under Scope, we've "Local" , "Global" and "Bus".Can anyone of you please explain how to use this?
I gone through the tutorial but still not get a clear knowledge in this.
Your help is extremely needed.
Thanks in advance.
Originally posted in cdnusers.org by harish.mellacheruvu@hcl.in
    It would help with all of your posts if you stated what version and product you are running.
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
    Iam using Allegro V15.7
    Local scope is used for matching within a (x)net only. Think of a net topology with a branch where you want the the branches to match one another but you don't care about matching to any other nets.
    Global scope is for matching net to net. In your example, you may want to match Drvr to Rcvr for every net in a group or bus.
    Local and Global are the only 2 scopes that exist at the net level. Bus scope can only be set at the ECSet level and controls how the Match Groups are created when the ECSet is mapped. Sounds like you might be trying to constrain a memeory interface. Bus scope was designed to cut down on the number of ECSets need to constrain an interface. It will create a separate MG for each set of nets (with a scope of global) grouped in a bus (by appending the bus name to the MG name in the ECSet). It allows for a single ECSet to be applied to several buses rather than using many identical ECSets that only differ by the MG name in the ECSet. For more detail see the following paper from CDNLive SJ 2007: Session 8.14: "How to use SPB 15.7 to Simplify Your DDR Constraints" by Mike Veal
    Originally posted in cdnusers.org by den
    Somone just pointed out to me that Mike's paper might not be included in the zip file of the proceedings for CDNLive SiliconValley 2007 (5_SPB.zip). Best way to get it is to navigate to the SPB tab for the 2007 proceedings:
    http://cdnusers.org/CDNLive/SiliconValley2007Proceedings/tabid/419/Default.aspx?topic=Silicon-package-board%20co-design
    Mike's paper is 2nd from the bottom.
    Dennis Nagle
    Cadence
    Thanks Den.
    This will help me.
