  3. Regardind SETUP--->USER PREFERENCES
  • Views 1940
archive over 17 years ago
Hi Iam New to PCB designing,Can any one says how to use SETUP--->USER PREFERENCES effectively
Originally posted in cdnusers.org by kingshar
    USER PREFERNCEs: use it with care.
    I explain: tis is only for user's prefrence settings. If someone else with another account open the pcb, then the result cn be different: some way to do DRC can be modified with user's preference.
    Sometime, if $HOME is not set for the user onmy (such as network drive) but only with local drive (C:), then the preferencee does not follow your account but is valid only on the speciifed computer.
    Knowing that, i do not use user's preference to modify path's or setttings impacting DRC's. I use CDS_SITE store informations in cpm's file.
    User's preference is fine to controle mouse behavoir and so on...
    Originally posted in cdnusers.org by jch teyssier
    My opinion? If you're new to Allegro - DO NOT - change preferences unless you've read up on the settings. These can drive you nuts! Leave well enough alone, and take your time to understand what they do.
    Good day.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
