  3. Regarding Manufacture--Variants ( Allegro PCB Performance...
  • Replies 7
  • Views 7604
Regarding Manufacture--Variants ( Allegro PCB Performance Option Version 16.01 )
archive over 17 years ago
Hello, When I select the menu option Manufacture--Variants--Create Assembly Drawing or Manufacture--Variants--Create Bill of Material , I get a error E- (SPMHSK-5): Variants file 'variants.lst' not found. Can anyone suggest a solution on this or tell me why am I getting this error? Regards, Prajakta.
Originally posted in cdnusers.org by psj
  • pterm
    pterm over 5 years ago in reply to madboss
    I'm just another user, not tech support.  I'm running Allegro 2020 17.4 in compatibility mode.  Since the menus change between releases, I doubt I could provide detailed instructions to you.
    I cannot tell if Cadence fails to create the variant.lst or if it places it in an unexpected place due to a path setting.   All I can suggest is running an exhaustive search of your file tree from the root directory.  If you find the file, you need to move it to the same directory as the BRD file.
    Good luck!  Sorry I can't be more helpful.
  • steve
    steve over 5 years ago in reply to madboss
    So you need to make the variants of your design using Part Manager first. Once they are there you can generate a varaint.lst and apply it to the PCB. Watch https://www.youtube.com/watch?v=S8U5mmUVS70
